03-21-2007 08:31 AM
03-22-2007 11:54 AM
This is not possible. Only later PXI-Controller (818x, 819x,...) can be booted into the realtime OS via BIOS settings. The older series has to use the bootdisk.
09-17-2007 11:43 AM
03-10-2008 03:54 PM
Notice the Andre says that you cannot dual boot using the BIOS settings, which I believe is correct. The newer controllers have a LabVIEW RT selection that boots the system. I believe it boots to the same partition where both the RTOS and Windows are installed, which must be FAT32. The newer controllers also will boot to RT safemode, using an minimal (i.e. few drivers - video and network) RTOS in ROM versus the RTOS on the hard drive (Very useful if RT software is not yet installed since it can then be a target from a Windows machine).
Needless to say, I think Matthias has the best solution for the PXI-8176. In this case, you are using a boot manager to point to a different Windows partition when booting to XP. The primary partition is the RTOS. There are sites that tell how to modify the BOOT.ini file in order to have Windows boot from different partitions. It is not too hard to have a menu presented to the user at boot.
