04-05-2014 03:35 PM
I'm having a problem in displaying results. I'm using Labview FPGA and i want to pass data from target to host program, then display the results on a waveform chart. The program works fine on simulation, once it is compiled on target i lose syncronization between pollted results. how this can be solved?
04-05-2014 09:52 PM
it can probably be solved fairly easily
04-06-2014 01:24 PM
Any suggestions about any of these ways?
04-07-2014 08:31 AM
do you try FIFO for data transfer between FPGA and host. are you sampling analog signal and displayed it on host (pc) . can you share snapshot of your fpga and host vi ?
04-07-2014 01:28 PM
I'm already using FIFOs between target and host and it is working fine on simulation. Once compiled an run the bit file i lose syncronization.
I'll try to get snapshots when i reach my office.
04-07-2014 02:30 PM
what are the signs of losing synchronization. did you miss the data in diaply you measured via fpga or some thing else
