08-04-2015 04:22 PM
I use DAQmx on Linux. I am now moving from SL6 to a newer distribution for my new computers. I struggle to get DAQmx to install.
If I try to install DAQmx straight, I get the following message:
Checking required install tools... Checking installer tool versions... dpkg Not found in current path rpm 4.11.3 can be used with a default installation path tar 1.28 Checking dependencies... glibc 2.19 Unpacking install files to /tmp/nidaqmx-8.0.2f0.install... *********************************** ERROR ************************************ * ERROR: 3.16 kernels are not supported! * * Running a 2.6.x kernel is required to continue this installation. * *********************************** ERROR ************************************ Installer is aborted.
Now, I understand that NI-KAL has to be installed first. So, I get it from the latest NI-VISA. NI-VISA 15 installs fine. But now, when I try to install DAQmx, I get this:
Installing NI-DAQmx for Linux Installer Distribution version 8.0.2f0... Pre Installation . Post Installation . Skipping nikali-2.1.0-f0.noarch.rpm installation, same or newer already installed. Skipping nipalki-2.6.3-f0.i386.rpm installation, same or newer already installed. Skipping nipali-2.6.3-f0.i386.rpm installation, same or newer already installed. Skipping nidimi-1.9.0-f0.i386.rpm installation, same or newer already installed. Skipping nimdbgi-1.3.1-f0.i386.rpm installation, same or newer already installed. Skipping nimxdfi-1.4.1-f1.i386.rpm installation, same or newer already installed. Skipping niorbi-1.9.0-f0.i386.rpm installation, same or newer already installed. Skipping nipxirmi-1.6.0-f0.i386.rpm installation, same or newer already installed. Pre Installation ............................... Preparing... ################################# [100%] file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nikali-15.0.0-f1.noarch file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipalki-15.0.0-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nispyi-2.8.1-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipalerri-15.0.0-f0.noarch file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipali-15.0.0-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package niorberri-14.1.1-f0.noarch file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package niorbki-14.1.1-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package niorbi-14.1.1-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimdbgerri-14.2.1-f0.noarch file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimdbgki-14.2.1-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimdbgi-14.2.1-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimxdferri-14.2.1-f0.noarch file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimxdfki-14.2.1-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimxdfi-14.2.1-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nidimerri-14.2.0-f0.noarch file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nidimki-14.2.0-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nidimi-14.2.0-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipxipfki-15.0.0-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nimdnsresponder-14.0.0-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package niapalerri-15.0.0-f0.noarch file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipxipfi-15.0.0-f0.i386 file /usr/local/natinst from install of niscarabmm-1.2.1-f0.i386 conflicts with file from package nipxirmi-2.8.0-f0.i386 [...]
file /usr/local/natinst from install of nidaqmxcapii-1.6.1-f0.i386 conflicts with file from package niapalerri-15.0.0-f0.noarch file /usr/local/natinst from install of nidaqmxcapii-1.6.1-f0.i386 conflicts with file from package nipxipfi-15.0.0-f0.i386 file /usr/local/natinst from install of nidaqmxcapii-1.6.1-f0.i386 conflicts with file from package nipxirmi-2.8.0-f0.i386 file /usr/local/natinst from install of nidaqmxcapii-1.6.1-f0.i386 conflicts with file from package niiotracei-15.0.0-f0.i386 Error installing NI-DAQmx for Linux Installer Distribution 8.0.2f0. Installer is aborted.
Is there any workaroung ?
Or is NI planning on updating the DAQmx installer, so that it is properly packaged with respect to the newer libraries ?
Thank you for your help,
08-06-2015 04:18 AM
Hi jsalort,
What distribution Linux do you use ? SL7 or SL6 ?
If you use SL7, it's not supported :
http://www.ni.com/product-documentation/52786/en/
Eloise
NI France
08-06-2015 04:47 AM
Hi Eloise,
Thank you for your reply. I am using 32-bits OpenSUSE 12.3.
Julien
08-07-2015 07:14 AM
Hi Julien,
Could you try to install DAQmx Base 14.0 (unless I am mistaken you try to install version 8.0.2 which does not support OPEN SUSE 12.3)
http://www.ni.com/download/ni-daqmx-base-14.0/5054/en/
Eloise
NI France
08-07-2015 08:09 AM
Indeed, DAQmx Base 14.0 installs fine. I don't know if my hardware will be supported with DAQmx Base though.
Is NI planning to update the DAQmx install package ?
Thank you
