Hi!
I got a problem with my new PXI system.
Steps I have done:
- Identify the System as external PC
- Identify the chassis as 1031
- The 6259 is visible under NI DAQmx cards
- pxisys.ini is present in the windows folder
- I can use the card for normal acquisitions
Problems:
- Card doesn´t show up under "chassis", slots 2-4 are empty (card is in slot 2)
- Due to this problem, I can´t use the trigger line for digital channels (want to use the 20MHz timebase as trigger source)
I have tried to deinstall the drivers for the 8310 several times, installed the full visa package and followed the guidlines I found in the knowledgebase and the forum here, but nothing helped so far.
Thanks for your help.
Yopp Qax
