06-15-2007 06:43 AM
06-18-2007 08:16 AM
Hi Crow,
Have you used a straight through Ethernet cable (i.e. not a crossover)?
When you boot the PXI into Real-time, does it display its IP address on the screen?
What is the status of the ACT/LINK led's on the Ethernet connection on your controller?
Seamus
NIUK
06-19-2007 04:28 AM
Hello Seamus,
Thank you for your response. I have managed to get it communicating with the host PC now (albeit in safe mode - won't communicate in 'normal' mode).
I am thinking that it is because I haven't configured my PXI system. When I identify the PXI system as a PXI-8140 RT series and the chassis as a PXI-1031, the chassis appears as unconnected with a message
'This chassis has been identified but is not described in the pxisys.ini for this system. This chassis was not present in the system during PCI enumeration'
Any ideas?
