PXI
Compatibility of PCIe-8361 with PCIe slot x1 rev2 ???
I have a new computer, Dell Optiplex 9020 with PCIe x1 slot rev 2.
Did the carte PCIe-8361 is compatible with slot PCIe x1 slot rev 2 ???
I didn't found any information on the documentation and the computer don't boot if the PXI carte is on and connected to the card.
Actually, I have a new computer with unusable system acquisition.
I asked French Technical support and they are very slow the help me.
Thanks in advance..
(5,450 Views)
We have also experienced this issue. The card does not reliably work with rev2 or rev3 PCIe slots.
(3,168 Views)
For information, the problem wasn't solved.
We work on the old computer.
Technical support has an unofficial list of computer with are not compatible
(3,159 Views)
Interestingly enough, I have issues too with the OptiPlex 7040 and 3050 models from dell. Using a pcie-8631 to a pxie-1078 chassis..  With a 6361 Daq and serialport cards, when using fifo buffers on the coms, data is getting trapped in the buffet and causing a buffer overflow which crashes' the system. Daq will only work on demand..  Are you seeing this issue too?
(2,473 Views)
