I have a new computer, Dell Optiplex 9020 with PCIe x1 slot rev 2.
Did the carte PCIe-8361 is compatible with slot PCIe x1 slot rev 2 ??? I didn't found any information on the documentation and the computer don't boot if the PXI carte is on and connected to the card.
Actually, I have a new computer with unusable system acquisition.
I asked French Technical support and they are very slow the help me.
Interestingly enough, I have issues too with the OptiPlex 7040 and 3050 models from dell. Using a pcie-8631 to a pxie-1078 chassis.. With a 6361 Daq and serialport cards, when using fifo buffers on the coms, data is getting trapped in the buffet and causing a buffer overflow which crashes' the system. Daq will only work on demand.. Are you seeing this issue too?
