04-16-2008 01:38 AM
Any ideas,
Shimon.
04-16-2008 06:25 PM
Hi Shimon,
Whats the specific error codes you are receiving, and how often do they occur? This information may explain why this is happening.
04-17-2008 09:52 AM
Hi Tolga,
My problems are as follows:
P.S At the PXI monitor there are no messages while the communication stops.
Shimon.
04-20-2008 11:20 AM
Hi Shimon,
Regarding your questions:
From what you've described, I doubt that the issue is due to your ethernet driver. The following KB describes why you may be getting poor performance when directly connecting to your RT system via a cross-over cable:
http://digital.ni.com/public.nsf/allkb/FD24D98FF428F21686256B64007FB6C1?OpenDocument
This tidbit I think may be the issue:
"If one ethernet card thinks it is running full-duplex, and another thinks it is running in half-duplex, problems can occur. If the half-duplex configured card receives a frame while transmitting a frame (which, if the other end is full-duplex this is entirely likely), then it may interpret that as a collision. When collisions occur frequently, network performance becomes very poor."
That document also provides instructions on how to change the ethernet cards to use the same duplex setup. Please follow those instructions and you may resolve the issue.
However, if you'd still like to reinstall the drivers, then the following KB describes the driver locations for the PXI controllers: http://digital.ni.com/public.nsf/allkb/B6BE8A0BFD128FBC86256DBF006E8F83?OpenDocument
Note that the 8176 is in the same series at 8171 PXI.
The driver is NOT written in LabVIEW, the ethernet driver is not an instrument driver, it is an Intel hardware driver.
Unfortunately, I am unable to provide you with our company email addresses. After following the above recommendations if you are still having questions, then you can upload pictures here, or through our ftp servers.
04-22-2008 02:33 AM
Hi Tolga,
Thanks for all your help, your reply helped me very much.
Shimon.
04-22-2008 02:33 AM
Hi Tolga,
Shimon.
