I have a Chroma 52914 model that has the same freeze up problem on start-up. If I wait about 30secs it will start responding.
I am using Labview 8.0 and the instrument driver from Chroma. I am also waiting for some engineering support on this issue.
This is not the only problem with this unit. Chroma has an exe which
can be used to operate the supply, and it seems to work OK.
For operation from Labview, they have an example VI, but I can't seem
to get it working. It will freeze up on some of the dialogs if you
click more times than expected, for example.
Has anyone got this working? All I really want is to set a current
limit and a voltage for each channel, but I can't get the "DC supply"
mode
to do anything. I don't even see a place to plug in the current,
voltage. The only feature that does anything for me is the sequencer
mode,
and that is probably more than I need.
