PXI
Chassis incorrectly identified, can't change it
Hello, I bought a case pxi-1031dc and set it pxi-8176 controller, it does not work on the Case, the monitor signal is not present, the workers tried many controllers, only one controller 8156 it works fine. I do not quite understand the problem in the case or something else? Because many with this briefcase and work with controllers pxi-8176.
Message 11 of 12
(756 Views)
Regarding your problem, have you tried the following troubleshooting steps?
- switching on/off
- removing the controller and re seating it
- tried with nothing else connected in the chassis
- tried with a different plug
- check fuses or circuit breaker on chassis and any other power supply
- try different controller in the same chassis (if possible)
- try controller in different chassis (if possible)
Message 12 of 12
(729 Views)
