01-30-2014 11:06 AM
I have a PXI rack with a PXIe-6341 and was wondering if this module will drive 5v solid state relays or if I need to
use a relay driver IC between the relay and the DIO lines.
thanks
01-30-2014 11:26 AM
The spec for the 6341 states a digital output drive current of 24mA. With that, you should be able to drive most SSRs. But do check the control currents just to be safe.
01-08-2015 01:49 PM
Are there any Labview examples showing how to use the PXIe-6341 to drive solid state relays?
Links would be appreciated
thanks
01-08-2015 01:57 PM
Do a search in the LabVIEW Example Finder (Help->Find Examples). You will want to find some DAQmx example that uses Digital Output.
01-13-2015 08:55 AM
I found an example that worked really well as it had both inputs and outputs for the
PXI-e 6341 (and other devices) but I seemed to have misplaced this VI and can't find it now
as it didn't automatically save itself on my PC as far as I know...
01-13-2015 09:36 AM
01-13-2015 10:34 AM
If there is a VI behind the NIDAQmx Test Panel for the PXI-e 6341, I would love to see it...
I have this device set up in my system and can see it in NI MAX but I am not sure how to
set it up for Digital outputs and then how to toggle the individual output lines in each of the ports...
Where can I find information on doing this?
01-13-2015 10:56 AM
Look for the Digital - SW-Timed Output.vi in the Example Finder.
01-13-2015 12:56 PM
The Look labview 2014 version of Digital - SW-Timed Output.vi errors out but the 2013 version doesn't.
But neither one works. Looks like it wasn't written for the 6341 module.
01-13-2015 02:37 PM
The Digital - SW-Timed Output.vi lists the PXIe-6341 as a device that can use this VI
but when I run it I get the following error:
Error -200463 occurred at DAQmx Write (Digital 1D Bool 1Chan 1Samp).vi:6940001
Possible reason(s):
Specified read or write operation failed, because the number of lines in the data for a channel does not match the number of lines in the channel.
If you are using the Digital Waveform datatype, make sure the number of lines in the digital waveform matches the number of lines in the channel. If you are using boolean data, make sure the array dimension for lines in the data matches the number of lines in the channel.
Number of Lines in Channel: 1
Number of Lines in Data: 8
Task Name: _unnamedTask<2>
