10-08-2015 02:08 PM
I am trying to export list of softwared installed on PXI chassis for archiving purposes via MAX. This way when i need to reinstall software on chassis i know exactly which drivers were used previously.
Solved! Go to Solution.
10-09-2015 09:32 AM
Hello drakkar,
You can create a NI Max report. For this please go to File >> Create Report. In here you can select for which system you want to create the report and the type of it.
Daniel M.
Applications Engineering
10-09-2015 11:51 AM
That will work. Thanks!
10-09-2015 11:54 AM
Hello drakkar,
Np, please mark the answer as a solution for your issue.
Daniel M.
