PXI
Calibration coefficients for PXIe-7856R
I am trying to use PXIe-7856R with raw data and software calibration. This documents gives a good background http://www.ni.com/tutorial/14834/en/, however I can't find the Nominal to Binary and Binary to Nominal VIs for the R-series. Any suggestions please?
Konstantin
(2,637 Views)
Accepted by topic author Konstantin
Hello Konstantin,
You can find them in <LabVIEW>\examples\R Series\Device Specific\PXIe MIO Devices\Stream Data\subVIs
Best Regards,
Nick
AE@NIUK
Everything has an End, and you get to it only if you keep on
-E. Nesbit
(2,607 Views)
Thank you Nick,
This is great and solves my immediate problem. Is this documented in any way? I could not find anything, ideally it should be in the user manual or in the reference.
All the best,
Konstantin
(2,604 Views)
Hello Konstantin,
No, it is not, I have found a similar problem for cRIOs and worked from there.
I am writing an e-mail to the owner of the tutorial right now to get it sorted out. I think that we will have it referenced in the tutorial or have the files attached.
Best Regards,
Nick
AE@NIUK
-E. Nesbit
(2,601 Views)
