05-28-2008 04:09 PM
05-29-2008 10:55 AM
Instrument | Recommended Model | Requirements |
Calibrator | Fluke 5700A | If that instrument is unavailable, use a high-precision voltage source that is at least 50 ppm accurate for 12- and 13-bit boards and 10 ppm for 16-bit boards. |
DMM | NI 4070, Agilent 3458A |
If these instruments are unavailable, use a multi-ranging 5.5-digit DMM with an accuracy of 40 ppm |
Counter | Agilent 53131A | If this instrument is unavailable, use a counter with an accuracy of 0.01%. |
Chassis | NI PXI-1042, NI PXI-1042Q |
Use with PXI modules. |
DAQ Accessory | NI SCB-68 | Shielded I/O connector block with 68 screw terminals for easy signal connection to 68- or 100-pin DAQ devices. |
NI CB-68LP, NI CB-68LPR, NI TBX-68 |
Low-cost termination accessories with 68 screw terminals for easy connection of field I/O signals to 68-pin DAQ devices. | |
Shielded DAQ Cable | NI SH68-68-EP | Use with NI 671x/672x/673x modules with a 68-pin SCSI II connector. |
NI SHC68-68-EP | Use with NI 6715. | |
NI SH68-C68-S | Use with NI 6722/6723. |
05-29-2008 01:07 PM
