PXI
CJTemp sensor location
I would like to know the location of the CJC sensor in the TB-2605, not indicated on the parts locator diagram.I plane to compare the temperature measured  by the CJC implemented in TB-2605 with that measured by a 1kohm Pt resistor connected on a  channel the nearest to CJC sensor position.I measured a difference of 0.2°C when the Pt resistor is connected on channel 7 after 2 hours using PXI-2503 with PXI-4071.
Best regards
Message 1 of 1
(2,679 Views)
