04-10-2008 01:50 PM - edited 04-10-2008 01:51 PM
04-14-2008 01:59 PM
All of the grounds including analog output, input and digital I/O are tied together to the common ground. For a PXI chassis that common ground is chassis ground which should be connected to earth ground via the power outlet that you are connected to.
If readings are different from one ground to another on the same card, the cable maybe damaged or the pins may be bent. If the power outlet that the chassis is connected to does not have appropriate ground connection then check the PXI chassis user manual to see how to connect safety ground.
I hope this helps!
