I have a PXI-4472 board and I would like to acquire my 8 channels simultaneously using an analog trigger. Since I also want to use the trigger signal as a reference signal to calculate a Frequency Response Function (FRF), I was wondering if there is a way to acquire the whole trigger signal even if it is connected to a Trig. or External Trig. input.
I'm using a PXI-1042 chassis which includes the PXI-4472 board (8 channels + external trigger) and general ports like USB, GPIB, etc. (and also a trigger input).
All inputs are microphones to perform array measurements and since I'll will displace the 8 microphones array, I absolutely need a reference signal.
Otherwise, I would have to use only a 7 microphones array with my reference microphone connected to the other free channel....
Thank you,
J-F
