03-14-2006 10:52 AM
03-15-2006 12:26 PM
Galen,
Looking at your vi, I would recommend writing to your file in a different way. The function you are using is actually opening, writing, and then closing the file every time you call it. This greatly increases the amount of resources being used. Take a look at the Cont Acq to Spreadsheet File.vi example and note that the file is only being opened and closed once. The data is being written to the file during execution of the program, and then closed when the app is done running. The example is done in traditional DAQ but you should be able to do something similar with DAQmx. Try this and let me know if it helps.
LA
