PXI
8371shutdown, power cycle.
'M currently using a PXI chassis controled by a PCI-PXI eXpress Link (8371).
I understood, it is necessary to power up the chassis first at PC startup.
My question deals with the power down. Usually I power down the PC
first and got a blue screen:
*** Hardware malfunction
Call your Hardware vendor or support
NMI: Parity check / Memory parity error
*** System has halted ***
Has I power down my chassis first it works fine.
That was never the case with MXI-2,3,4 controllers.
May you help me please to fix it or explain it to me.
Thanks.
David
(3,635 Views)
Hi Darkdave.
You are acting right when booting the chassis first. It won't work if you act the other way.
Is it a problem for you to stop the chassis first ? After a few discussion with colleagues that have used MXI chassis, it appears that they always stop the chassis before the computer and then never get any problems.
I noticed that the kind of error you get appears with some other HW and this only with certain motherboards chipsets. Do you notice the same error with other computers (that have different motherboards ?)
Let me know.
(3,613 Views)
Hi Darkdave,
Some more precision, since I now know the exact power cycle.
Chassis connected through MXI always must be started before the PC and shut down after the PC.
When you turn the system on, BIOS assigns memory, I/O space ans device number what requires the chassis to be already on.
When you power the system off, you have to shut the PC first since OS ans drivers expect all PCI devices to be connected (they actually except them to be connected from power up to power down)
If you power down the chassis first you will certainly experience system hang or blue screen. In your case this is caused by the interaction between windows and the PCI Express silicon that is present on MXI-Express. When windows is shutting down, it actually sends read signals to all connected HW, and waits for such HW to respond before it shuts down. Getting a blue screen means that your HW doesn't respond fast enough what implies windows to time out and causes a blue screen.
Note that you will not encounter blue screen on all system and that it depends on your motherboard. Please note that it doesn't damage your system and will happen infrequently.
There is workaround this issue between Microsoft and PCI Express silicon vendors
Best regards
P.S: Thanks Tica for this information
(3,580 Views)
Hi Mathieu,
thanxs a lot for those precisions. You unsderstand my mind , wishing
to know the reasons why...
Hope to have more to ask you next time.
Merci.
(3,575 Views)
