05-09-2014 04:40 PM
I am new to form. I am using LabView NI-PXI1033 chasis and connected with NI PXI-7851 RIO device. I used to get 5v output from pin 1 and 35 in SCB 68 connector pin. I use connector 0 of PXI-7851R. But now I am not getting any output from those pins. what can be possible reason. But I got digital output, analog input and output. Only 5v supply is not working. why?
waiting for reply.
with regards,
reaz
05-11-2014 03:19 PM
You might have blown the fuse that is on the board for the 5V output. What do you have the 5V connected to? How much current do you need to draw from it?
05-12-2014 11:51 AM
Thanx. You r right I blew the fuse. I did not know there is another fuse inside the PXI.
