02-05-2007 12:07 PM
02-06-2007 11:05 AM
Hi ULEng,
Do you mean a PXI-4462? To my knowledge we don't sell a 4662. How are you connecting this signal - are you just reading an open connection, or reading a known source? What is the amplitude of the signal (Screenshots are useful) and at what rate are you sampling? Also, how did you determine that its at 510hz - FFT?
If you're reading off of an open channel the noise shouldn't be too unexpected, you'd be reading a floating signal with no path to bleed off any charge that accumulates. Open connections are very susceptible to noise - is the noise still there if you read a signal from a battery, power supply or function generator?
I was a little confused about how LabVIEW 8.2 played into this - did you upgrade from another version or are you just getting started?
Hope this helps, please post back if the troubleshooting doesn't help.
Cheers,
Andrew S
02-06-2007 12:32 PM
02-09-2007 01:26 PM
Hi ULEng,
Did you not see this noise before with LabVIEW 8.0, or is this just when you noticed it? Do you still see this noise when you input a known signal? What is your concern with this - the fact that you're seeing the signal, or that it showed up after an upgrade? I want to make sure that I adress your issue rather than getting side tracked on something irrelevant.
thanks,
Andrew S.
