PXI and Instrumentation Idea Exchange
Community Browser
About PXI and Instrumentation Idea Exchange
Have an idea for new PXI hardware or software features?
  1. Browse by label or search in the PXI and Instrumentation Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Post an idea
Please submit your feedback regarding our existing PXI products and ideas for new products as well. If your idea has been previously submitted, be sure to vote for the idea by giving it kudos to indicate your approval!
I have an upcoming requirement for connecting two test equipment racks so that one contains a control computer and PXI chassis and the second rack contains another PXI chassis. The control computer will include a two-port MXI Master PXIe card, and each PXI chassis an MXI Slave card.
The problem arises that there is no means to bring out an MXI cable from one rack to the other, except through a hole, rather than a proper feed-through connector.
I can design and build a back-to-back pair of MXI matching Molex connectors on a small PCB, but a qualified, tested, and approved OEM solution would be much better.
