03-25-2010 03:35 PM
Hi, i have 2 CCTV cameras which have their own program to preview, but how can I grab them on labview and what are the modules that i have to work with ??
can anyone give me an example vi for this ?
03-26-2010 05:13 AM - edited 03-26-2010 05:16 AM
03-26-2010 05:24 AM
03-26-2010 11:35 AM
these are the specifications of the card, it is a BCN input type
Specifications
Input Type | BNC | BNC X 4 | ||
D‐Type | DB15 X 2 | |||
Video Input(s) | 1, 2, 4, 6, 8, 10, 12, 14, 16 Cams | |||
Audio Input(s) | 1 Channel | |||
Total Recording Rate At 320 X 240 Resolution / MPEG (ASP) | 30 fps (NTSC), 25 fps (PAL) | |||
Display Rate | 30 fps (NTSC), 25 fps (PAL) | |||
Video Resolution ‐ NTSC/PAL | Full D1, Half D1, CIF | |||
Compression Format | Geo MPEG4, Geo MPEG4 (ASP), Geo H264, Geo H264 V2 | |||
GV‐A16 Support | Yes | |||
GV‐NET Card Support | Yes | |||
GV‐NET/IO Card Support | Yes | |||
Dimensions (W x H) | GV‐600 BNC / D‐Type : 145 x 98 (mm) / 5.71 x 3.86 (in) |
03-26-2010 12:45 PM
03-26-2010 01:18 PM
it is 1/4 sharp camera and it is color ccd camera connected with a coaxial cable to the card
hope that is helpful
03-26-2010 03:41 PM
03-29-2010 05:30 AM
04-01-2010 05:43 PM
04-02-2010 12:52 AM
That's NOT true. LabVIEW can connect to any instrument, you just need to know the protocol and figure out how to talk to it (if possible) through LabVIEW. The camera will not show up in Vision Acquisition Software if it communicates through a DLL or ActiveX interface. In any case, have a look at the release notes of the VAS. And, here is another important link: Industrial Camera Advisor.
