NI مناقشة حول منتجات
مشكلة في crio
السلام عليكم
لدي جهاز cRIO9004
لا يظهر في MAX
هل من مساعدة ؟
(8,272 Views)
That's probably because there is a conflct with the firewall or an IP conflict between your PC and the cRIO. Make sure you disable the firewall first. If that doesn't work, reset the cRIO to reset the IP. There is a small Reset button on the cRIO that you need to press, then connect the cRIO to the PC and set the IP on the same subnet. Have a look at:
CompactRIO cRIO-9002/9004 Operating Instructions
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(8,270 Views)
لمن يستعمخل لابفيو بالعربية
حماده بن ناصر
http://labview.tech.officelive.com
(8,181 Views)
لمن يستعمل لابفيو بالعربية
د\حماده بن ناصر
(8,179 Views)
(8,177 Views)
د\حماده بن ناصر
(8,173 Views)
د\حماده بن ناصر
(8,172 Views)
