04-01-2010 03:02 PM
Did you know that Multisim supports just about any SPICE model? This means that you can import pretty much any SPICE model available on a manufacturer’s website directly into Multisim and start simulating. Throughout the past few releases, we have made explicit efforts to support even proprietary SPICE models, like PSPICE, to increase the breadth of options available to circuit designers. That’s right – you can use models from other tools directly within Multisim.
The purpose of this thread is to list places to find SPICE models. Of course, it's always a good idea to verify the model before using it (especially if the model was created by an individual). Please add to this list, and if you have created your own models, feel free to share them on the Documents tab of this community.
Manufacturer Created Models
Manufacturer | Device Types |
Aeroflex | Abrupt Varactor Diodes, GaAs Shottkey Diodes, Step Recovery Diodes, Schottky Diodes, Tunnel Diodes |
Analog Devices | Amplifiers, Comparators, Switches, Multiplexers, Voltage References |
AXV | Capacitors |
Cirrus Logic | Amplifiers |
Coilcraft, Inc. | RF Inductors, Power Inductors |
Diodes, Inc. | Power MOSFETs, Diodes, MOSFETs, BJTs |
Epcos | Inductors |
Fairchild Semiconductors | Bipolar Transistors (BJTs), Diodes, Power MOSFETs, Opamps |
Infineon Technologies | Diodes, BJTs, MOSFETs, |
International Rectifier | Power MOSFETs, Diodes |
Intersil | Buffers, Opamps, Comparators, Video ICs, Power MOSFET Driver |
Linear Technology | Opamps, Comparators, Voltage References and Regulators |
LittelFuse | Circuit Protection Application SPICE Models - varactors, special diodes, SCRs, Thyristors |
Maxim | Amplifiers, Analog Switches and Multiplexers, Clocks, Counters, Comparators, Delay Lines, Oscillators, RTCs, Data Converters, Sample-and-Holds, Digital Potentiometers, Fiber and Communications, Filters (Analog), High-Frequency ASICs, Hot-Swap and Power Switching, Interface and Interconnect, Memories: Volatile, NV, Multi-Function, Thermal Management, Sensors, Sensor Conditioners, Voltage References, Wireless, RF, and Cable |
Microchip | Opamps, Power MOSFETs, MOSFET Drivers |
National Semiconductor | Opamps, Audio Applications |
NXP Semiconductor | Complex discrete models, Diodes, MOSFETs, RF FETs, Wideband Transistors, Shottky Barrier Didodes, Small Signal Transistors |
ON Semiconductor | AC-DC Controllers and Regulators, Amplifiers and Comparators, Bipolar Transistors (BJTs), Clock Generation, DC-DC Controllers, Converters and Regulators, Clock and Data Distribution, Diodes, Drivers, EMI/RFI Filters, FETs, Interfaces, Memory, Rectifiers, Standard Logic, Thyristors, Votlage Controllers, References and Supervisors |
Polyfet | Polyfets |
Renesas | MOSFETs, Diodes |
ROHM | Transistors (Small Signal, Digital, Bipolar), Diodes (Shottkey Barrier, Zener, Fast Recovery, Rectifier, Switching, High Frequency), LEDs (PICOLED), Tantalum Capacitors |
ST Microelectronics | Opamps, Comparators, Power MOSFETs, Diodes, Thyristors (Triacs, Diacs and SCRs) and IGBTs |
Texas Instruments | Opamps, Comparators, Filters |
Vishay | Power MOSFETs, Diodes |
06-26-2017 07:35 PM
Do you have any NI tools, preferable Labview vi, that can be used to build spice models based on data Sheets?
