07-08-2013 03:58 AM
There is this LabVIEW robotics module that you can use to control the motor. Please give it a try and let me know if you can find the required APIs.
07-08-2013 04:00 AM
Dear All,
The hardware loaning process is now on. For any hardware loaning queries, please visit https://decibel.ni.com/content/docs/DOC-30191
Regards
Bharath Dev
07-08-2013 09:44 AM
thank you for your reply sir,
these are my doubts where i want to maintain my data base and by using which tool i need to compare my acquired image and the image which was in my data base...
so please kindely help me to complete my project...and correct mu vi code....
07-08-2013 10:01 AM
sir,
these VI's will work if we use 3rd party motors...
or ni can provide the motor....
if any example code you can provide will be very beneficial for us
Regards
Saurabh Saxena
07-08-2013 09:57 PM
Sir, I want to use a C++ code in labview how can i do this?
07-09-2013 08:18 AM
There are couple of ways you can use your C++ code in LabVIEW. There is a node called "Formula Node" where you can write simple C style math operations inside LabVIEW.
But if you want to your extensive C++ functionality, you need to build a DLL(Dynamic Link Library) out of your C++ code. You can google out for the procedure to build a dll from C++ code if you not aware of it.
A DLL can be called in LabVIEW by using Call Library Node.
Regards
Bharath Dev
07-09-2013 08:19 AM
For getting the hardware, you need to send a follow the procedure that I have mentioned in one of the posts. Let me know if you find any difficulty in procuring the hardware.
07-09-2013 08:23 AM
To do database operations, you can use NI Database connectivity toolkit. This helps you to create and connect to database and you can do all the operations like Insert and Select.
There is no specific NI tool to compare images. This will be part of your assignment to write the comparer. You can check out Snag It! tool which is available on web. This uses advanced comparison techniques. But I would suggest you to write a tool on your own.
Regards
Bharath
07-09-2013 11:07 AM
by using which tools i want to form a algorithm(comparer) in labview.. and how to form it..?
07-09-2013 11:59 PM
Sir,
We hav taken OWI ROBOTIC arm and we are trying to program it. But the problem is in the arm we hav dc motors , we are trying to control it using motor driver ic L293D. Can we use daq 6009 (usb), to control arm...if yes could u tel us how to do it,,,or atleast a link wher we can find some info.....on it..
thank u
