NI VideoMASTER and NI AudioMASTER
Image operation
Hello everybody,
I am trying to do a simple task yet I have been unable to complete it successfully.
I have an avi video and I want to extract a particular frame from it, then I want to subtract this frame to other frames in the video, this could be helpful for instance to remove the background from a video. The video corresponds to a bubble that grows and collapses in a few frames.
I am able to do the subtraction from operation (i.e.. Frame 2 - frame 1); I then convert the resulting image to a grayscale image (SSL) with the IMAQ cast image VI/ However, the resulting image is all black. I expected to see the difference between the two images as a dark ring that shows the growth of the bubble and not only a black image.
Can somebody give me a hand with this problem?
I am attaching the VI and the video(Test.avi).
Rob
(7,977 Views)
Hi Roberto83
You probably have to allocate memory for both Frame A and B by using IMAQ Create.
See attached VI.
(7,963 Views)
Thank you for your assistance Vegemite.
I was unabel to open the vi because I am using version 8.5, by any chance can you save it a an 8.5 version.
Thanks again
Rob
(7,960 Views)
Hi Rob
here is 8.5 version of VI.
(7,946 Views)
