NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
JEFF2 LEE
Chrominance Non-Liner Phase
Dear All, Our measured environment as below Video stream source USB disk or DVB-C Stream file “NTC7.TRP” from Tek Measured equipment NI PXI-1042Q VideoMaster Fail item Chrominance Non-lin Phase See the attached .png file, You can see the fail at Phase Packet 1/3. The -359 degree of result occur frequently. As well-know, -359 degree should be +1 degree ?? The attachment aslo inculde Tektronix VM700 waveform, and wihout issue.
Member
Nick_Storton
Re: Chrominance Non-Liner Phase
Hi Jeff2Lee,
Could you let us know which version of VideoMaster you are using please?
Nick
Member
JEFF2 LEE
Ther videomaster version is 1.4.8.according to our customer spec is +- 2 degree.
but we found videomaster showd -359 degree, it's big problem for us. it should be +1 degree right ?
Thanks for your answer.
Member
Nick_Storton
Hi Jeff2Lee,
OK so that is quite an old version of VideoMaster and I believe that there might have been an issue in the earlier versions with just this problem. You are right that this should read +1 degree. I would recommend that you contact your local NI office and ask about updating your version to the latest version. I have made this measurement with later versions than this and have not seen this issue.
Hope this helps,
Nick
Member
JEFF2 LEE
Dear Nick,
  Thanks for your help! I will call NI people for solve this issue.
Member
jeff2_lee
Dear Nick ,
   What's version videomaster recommand for fix -359 degree issue ?
   Cause we cann't get correct information from local NI .
Member
Nick_Storton
Hi Jeff2 Lee,
You would need to update to the latest version which would be V3.1. I think the issue was fixed in either V3.0.1 or V3.0.2. There may also be a cost involved in this update but you would need to check with your local NI guys.
Nick
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
