03-20-2013 07:06 AM
Harris,
So the older stimulus profiles manipulate the channel successfully after being mutated to the newer version?
Can you please upload a older profile and I'll like to take a look at the xml behind it to see if something is different. I want to double check there isn't anything different that isn't being called. You can also access this by opening up the files with simple text editor like notepad++.
Thank you,
Kyle H
03-20-2013 11:00 AM
Hi Kyle,
Yes, from what I remember, the older stimulus profiles work with the Generator Engine State properly. I will confirm again later today. Attached is a mutated profile as you requested. Thank you.
03-20-2013 05:09 PM
Yes, I confirmed that the mutated old stimulus profiles do affect the Generator Engine State. The new profiles do not.
03-21-2013 04:46 PM
03-21-2013 04:46 PM
Harris,
That channel only exists for the legacy profiles it isn't used by the newer stimulus profiles. So that explains why they aren't updating. There isn't a replacement for it either. You'd have to create something yourself to recreate that functionality.
03-22-2013 12:13 PM
I see. If there's no channel available, I don't see how I can access the running of the stimulus profiles. I guess I'll put this into the idea exchange forum for a future release.
