09-16-2011 03:26 AM
Hey Guys,
I installed VeriStand a few Days ago and now I would like to connect LabVIEW and VeriStand.
I already explored how to run a stimulus profile in an open VeriStand Workspace from a LabVIEW VI.
Now I would like to open & run the Workspace (like the "run project"-button at the VeriStand Getting Started Window).
Does anyone know how to do that?
I have attached my current Status, but I guess I don't use the right VIs.
Frank
Solved! Go to Solution.
09-16-2011 07:59 AM
There is a set of VIs you can use to do this. They are not on the palette, but you can find them in the NI VeriStand folder under vi.lib at <LabVIEW>\vi.lib\NI VeriStand\Execution\Project.
There are VIs to open a project, run it, open the workspace, etc.
The VIs you are using only control the System Definition, not the VeriStand Project and the Workspace.
09-16-2011 09:15 AM
Thanks, I will try this first thing on monday.
have a great weekend!
11-06-2012 07:15 AM
Hello All,
I'm also trying to start VeriStand from LabView but I can not.
I tried to use "OpenProject" but the result is the one you see attached.
Can you help me please?
Thank you very much
monica
11-06-2012 08:04 AM
Use the System Exec function in LabVIEW to start the NI VeriStand application. Just pass in the path to the NI VeriStand.exe file. After that, you can call OpenProject to open a specific project from there. Just note that it will take VeriStand a few seconds to initialize once the exe is started, so if get error 1172 again, wait a few seconds and try calling OpenProject again.
11-06-2012 08:59 AM
Thank You very much Jarrod!
....excuse my ignorance but are not practical of command line, would you be so kind to tell me the command to send?
thanks again
monica
11-20-2012 10:50 AM
Hello everyone,
I used to open the NI VeriStand the "constructor node" with the process but I can not open the project; can anyone help me?
