01-20-2011 05:38 PM
Is there any way to change the default Timed Loop rate?
An old post said I can specify a decimation factor or something. But I think that is to change the iteration of PCL to read/write channel FIFO, not TimedLoop rate.
Any suggestions?
Thanks.
10-17-2013 03:29 PM
In a custom device you can use Timed Loop or While Loop.
If you use while loop, you can use wait until function.
If you use a Timed Loop, a custom timing source is normally linked to the Timed Loop to configure it.
You can wire a constant if you want.
Caution : Timed Loop can cause Watchdog error so I davise you to check the box "filter watchdog error" on the system definition file configuration.
R. Kaszubiak
