10-21-2013 04:20 AM
Premise: All of my simulation targets are Windows(localhost).
I use VeriStand .Net API as follow:
1. create SystemDefinition File(generate .nivssdf file with model1);
2. new Factory();
3. GetIWorkSpace2();
4. ConnectToSystem(sdfpath, true, 600000);
5. GetSingleChannelValue(varname, out val);
and I can get values correctly. but i want to change the model to model2, so i edit the sdf file with RemoveNode() and AddModel(newmodel) after call "DisconnectFromSystem("",true)". And i get a new .nivssdf with model2. Then i start from the third step. No error is displayed, but the value i get from GetSingleChannelValue(varname, out val) is the value of model1.
After i import my new .nivssdf(with modle2) in VeriStand, I can get values correctly.I think i do not clear something which is used again when i deploy my new sdf file. Help!!!
Solved! Go to Solution.
10-22-2013 08:38 PM
I found that i must change the target name to get correct result when i change the model.dll. Why???
10-28-2013 08:42 PM
