04-08-2016 08:09 PM
hello,
I made a deployment utility that allows someone to just deploy a sysdef file without using the veristand GUI. They can select IPs for each target, calibration files (optional), and click deploy. Works great. However all I display is a busy curor during deploy. Is there any way to get the text, through an API, that using the veristand GUI would normally show?
Thanks!
Solved! Go to Solution.
04-09-2016 11:38 AM
04-11-2016 01:27 AM
Hi all,
Your right there are 3 events you can catch:
_workspace.OnGatewayErrorNotification += new DOnGatewayErrorNotification(_workspace_OnGatewayErrorNotification);
_workspace.OnGatewayStatusNotification += new DOnGatewayStatusNotification(_workspace_OnGatewayStatusNotification);
_workspace.OnSystemStateChange += new DOnSystemStateChange(_workspace_OnSystemStateChange);
I'm quite sure, "OnGatewayStatusNotification" is the one that gets the text messages displayed in the starting window.
Best regards
04-11-2016 02:25 PM
Worked great thanks guys
