11-19-2015 12:47 PM
I have a RT PXIe Chassis with a PXIe-4497 sound and vibration card running in Veristand 2013. I am trying to record the waveform AI channels I'm monitoring on it but having a little trouble. Here are some photos of what I have in my system file:
Setting wise I have logging enabled, no trigger (should just start logging when I enable the task). My issue is I can run the project and see the waveform on the front panel (see below) but when I go to the log file directory there is nothing there. Does anyone have any ideas?
Thank You,
Alec
11-19-2015 02:22 PM
The log file path in your configuration refers to a location on the computer where the engine is running. You mentioned you have an RT PXIe chassis. Are you looking on that computer for the files, or on your local PC?
11-23-2015 12:16 PM
Thank you! I was able to find them on the RT.
