NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
Lunik
Veristand & Alarms not working when multi alarm are set
VeriStand can not trigger more one alarm at the same time
Is it a bug or not ?
Active Participant
Florent_A
Re : Veristand & Alarms not working when multi alarm are set
Hello Lunik,
In the system explorer, you can define Groups of Alarms. In a group, alarms are evaluated sequencially, and alarms in different groups are evaluated in parallel.
Florent A. - AE Manager - NI France
Active Participant
Lunik
how I should set the alarm response for mutliple alarm ?
Active Participant
Florent_A
Hello Lunik,
It's all depend on what you need :smileyhappy:
how do you want to response? and where? on the host side or the RT side?
You may want to call the same procedure for differents alarms triggered
Active Participant
Lunik
When i set the same procedure for multi alarms i got only the first alarm and not the other
Member
h_yong
I've found that if multiple alarms are of the same priority, and one alarm is always being triggered because the condition is continually met, it may prevent the other alarm from triggering. In general I've put a small delay on all alarms so that other alarms will get an opportunity to trigger.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
