VeriStand
Veristand Problem: When Configurin​g a project, searching for a library file as a dependent file
The problem that I am having is that I took all of the necessary files in order to run a project and moved it to a different computer. When I open Veristand, and try to configure the project, a pop up window comes up with "Search for Dependent File: [filename]". It then says the missing file and the search directory. You can also browse for the file. So, for about the first couple of files, I just browsed for it and it was fine. But when it reaches a library file, I try to open it and it opens the library inside of Veristand. I think it thinks that I'm trying to get the file from inside of the library instead of the library itself.
Any thoughts greatly appreciated.
Message 1 of 1
(3,903 Views)
