02-02-2016 07:32 PM
Using a PXI 8110 and NI Veristand 2015, no matter what I set the PCL processor assignment to in the system definition, the PCL always land on CPU 0. I can confirm this with the CPU load monitor and an execution trace (attached).
The data processing loop moves around to my assignment as expected.
Solved! Go to Solution.
02-02-2016 07:47 PM
I cannot attach my system def, but I tested this with a blank sysdef +1 DAQ card and the problem occurs
02-03-2016 05:36 PM
Interesting! I'll see if I can reproduce this behavior on my end and let you know what I find out.
02-05-2016 04:46 PM
Hey Stephen, I was able to reproduce the issue you described on a PXI-8133. I've gone ahead and filed CAR 571818. What kind of an impact has this had on your application?
02-05-2016 04:47 PM
So far none. Just noticed it and wanted to report it
02-05-2016 04:48 PM
Although I dont know if there is something more sinister going on, and this is just a symptom
02-05-2016 04:50 PM
Understood. Well I'm glad to hear it's not causing you too much trouble - thanks so much for bringing it to us! The CAR I filed should get to the right people early next week.
Have a great weekend Stephen.
02-08-2016 03:26 AM
Corrective Action Request 571818
CLA, CTA, CLED
02-08-2016 09:19 AM
Thanks Jiri_K - completely forgot to include the number!
02-22-2016 09:55 AM
Thanks for reporting this, Stephen! R&D is looking into this issue. We believe we have narrowed down the cause for this issue, and we are evaluating a solution.
