01-25-2016 08:15 AM
I have a problem during the deployment of sinewave demo on RT target (cRIO9012).
My configuration is:
Labview 2012
Veristand 2012
The error is:
• Start Date: 25/01/2016 15:06
• Loading System Definition file: C:\Users\Public\Documents\National Instruments\NI VeriStand 2012\Projects\Example\Sinewave Delay.nivssdf
• Initializing TCP subsystem...
• Starting TCP Loops...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307853 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand: The VeriStand Gateway was unable to establish a connection with the target. Confirm that the target is running and that the VeriStand Engine successfully has started. If you still cannot connect to the target, use MAX to reinstall the NI VeriStand Run-Time Engine to the target.
NI VeriStand: Server TCP Interface.lvlib:TCP Connection Manager.vi:1
<append>=========================
NI VeriStand: Error 63 occurred at TCP Open Connection in Server TCP Interface.lvlib:TCP Connection Manager.vi:1
Possible reason(s):
LabVIEW: Serial port receive buffer overflow.
LabVIEW: The network connection was refused by the server.
Target: 192.168.35.45
• Unloading System Definition file...
I have also reinstalled NI VeriStand Run-Time Engine to the target, but nothing.
Can anyone help me, please
01-26-2016 05:01 AM
Hi Vincenzo,
I found a document that can help you.
Hope it helps, but let me know!
Have a nice day.
FBM
01-26-2016 05:13 AM
Thank you so much,
I will let you know
07-25-2017 04:08 AM
I faced the same problem.I hope you can tel me how to solve this priblem ,Thank you!
