12-16-2015 12:15 PM
Hi
When adding a Simulink model(R2014b) in VeriStand (2014), VeriStand crashes :
I have successfully added other models , so what's the problem with this, please.
I attach the Crash screen dumps and the diagnostic files
Many thanks
Mal
12-16-2015 12:55 PM
There are some known issues with importing MDL files directly. In general NI recommends compiling your model into a DLL to run in VeriStand, even when doing simulation-only tests on Windows. We removed the feature to run uncompiled MDL models in VeriStand 2015.
Here are some known issues you might check for in your MDL that might cause VeriStand to crash.
- Block names that start with a number
- Port-widths set to zero
- Accelerator mode turned on
12-16-2015 01:19 PM
Elaborating on Jarrod's response, please read the following knowledge base articles to assist you in configuring the system to compile models.
Compiling a Model from The MathWorks, Inc. Simulink® Software
12-18-2015 06:12 AM
Thanks for the sound advice , DLL approach is the only way !
