VeriStand
Using FIU 2510
I am using FIU 2510 first time. As per the user manual, I have connected the Pin 1 and 2 of the Phoenix contact to Channel and BUT respectively and the pin number 42 and 47 to the Supply and Ground respectively. Now I have assigned one channel in workspace to my one Digital Output from PXI and one Fault bus also from the same. Now if I want to crate fault by grounding that DO High pin of DAQ, what should I control the Channel and Fault Bus in GUI? Kindly suggest
Message 1 of 1
(3,460 Views)
