First time using VeriStand 2011 to connect to an external device. I am trying to connect to a PXI-8101. However, even with a brand new project, I am unable to connect to the target. I get the error code -307853, LabVIEW serial port received a buffer overflow and that the network connection was refused by the server.
The connection with the PXI-8101 is good, as I am able to connect to it using LabVIEW and MAX.
Attached is a screenshot of the settings I am using to connect. I have tired an assortment of settings, with none being successful.
