05-10-2016 02:50 PM
Is it possible to use a Tab Control from LabVIEW in a workspace object? I have one now and it is not functioning as expected...
Solved! Go to Solution.
05-10-2016 03:14 PM
Found solution: Wire output of tab control to value property node of the same tab control in event case. Tabs will change in VS when not in Edit Mode.
05-10-2016 03:20 PM
Tab control works even without event case, just change the tabs when not in Edit Mode in VS on the UI screen.
