VeriStand
Tab Control in Workspace Object...
Is it possible to use a Tab Control from LabVIEW in a workspace object? I have one now and it is not functioning as expected...
(3,496 Views)
Found solution: Wire output of tab control to value property node of the same tab control in event case. Tabs will change in VS when not in Edit Mode.
(3,492 Views)
Accepted by topic author swbpnole
Tab control works even without event case, just change the tabs when not in Edit Mode in VS on the UI screen.
(3,489 Views)
