10-15-2013 08:42 PM
I made a s-function in simulink with NIDAQmx.lib and NIDAQmx.h, and i can build it and generate a dll successfully with NIVeriStand.tlc.
I can use the dll with Windows target, but i can not use the Pharlap target, the deploy error is :
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details: Error -307703 occurred at Project Window.lvlib:
Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
10-15-2013 09:32 PM
http://forums.ni.com/t5/NI-VeriStand/Error-307703-while-deploying-a-dll-created-by-Simulink-R2011a/m... probably tell you what is the problem. You can use console viewer, http://zone.ni.com/reference/en-XX/help/372846F-01/veristand/console_viewer_tool/, to see problem detail.
10-17-2013 10:44 PM
I do not have the problem in your first link, i can use my simulink model with no error, except i use the NIDAQmx.lib.
and your second link is lost, i can not open it.
