01-18-2011 11:51 AM
I want to connect 3 analog inputs to the NI PXI-7831R Reconfigurable I/O Module, using the SCB-68 M series terminal block. I've noticed a discrepancy between the analog inputs, shown on the SCB-68 terminal block Quick Reference Label, and the analog inputs shown in the NI PXI-7831R connector 0 pinout diagram. For example, the NI PXI-7831R connector 0 pinout diagram shows AI3- and AIGND3 on pins 29 and 30, respectively. The SCB-68 Quick Reference Label shows AI GND and AI 3 on pins 29 and 30, respectively. There are at least six other cases where there is a mismatch between the Quick Reference Label and the pinout diagram. Has anyone else seen this?
Solved! Go to Solution.
01-19-2011 06:14 PM
Which SCB-68 Quick Reference Label are you looking at? The M Series would be for the M series DAQ cards where as the PXI-7831R is in the R-series. You can see the difference here in this KB which has both the M Series connector and the 7831R M Connector.
Hope this clears things up!
Regards from Austin,
01-20-2011 06:24 AM
Thanks, Ben - I was looking at the wrong Quick Reference Label
09-27-2014 02:45 AM
Hi
1. Iam not able to get any digital signal ouputs for an open loop VI on the SCB 68 connector box. Iam wrkng with labview based FPGA NI 7831R with the R series . what can be the problem.
2. can we use M series instead of R seires fro 7831R
09-29-2014 02:08 PM
Hi gudey,
This is a fairly old thread that isn't really relevant to your question, so I would recommend creating a new discussion that will be more relevant to your specific issue.
If you do, please supply us with the following:
1. Hardware configuration (how are you looking at the digital output?, which cable are you using for connecting to the SCB-68?, etc.)
2. Are you running a LabVIEW example? If so, which example, and which LabVIEW version?
3. What are you trying to accomplish? R Series and M Series devices will not be able to use the same code, but you could use either of them for multiple applications.
Again, please create a new discussion (feel free to refer to this one) for easier tracking. Hope this helps!
