03-21-2016 10:12 AM
Is it possible to programmatically update custom scales after the project has been deployed?
I'm working on a custom calibration routine using VeriStand as a back end HAL. We regularly do flow meters which use a lookup table as a custom scale. After calibration, this lookup table is going to change, so this needs to be done programmatically. Unfortunately, I have found nothing in the API, and Google returns either a bunch of results about custom devices or about doing it with a DAQmx task. The only other option I can think of is finding the table in the system definition file and undeploying / redeploying the project to force updates to happen on the RT target. This seems... a poor choice.
-M
03-21-2016 06:14 PM
03-21-2016 07:01 PM
