07-25-2016 08:24 AM
Hello !
I'm using a CRIO 9081 under veristand. I can see this chassis and the I/O modules.
But i also have a 9144 Ethercat connected as a slave, and i can't see it (and it's CAN modules) under veristand when i use the custom device "Scan engine and EtherCAT".
Do you know how it's possible to see it ?
(hardware connections are ok, all the software needed are installed...)
07-25-2016 11:22 AM
Did you use the "Auto-Detect Modules" feature of the Scan Engine and EtherCAT custom device? Or did you add the 9081 EtherCAT master and local chassis manually? If you tried to auto-detect and it didn't show up, make sure you have the appropriate ethernet port on the 9081 set as an EtherCAT master in MAX.
Do you have LabVIEW? If so, have you tried verifying that you can add both the 9081 and 9144 in a LabVIEW project?
07-26-2016 01:51 AM
Yes i'm using the Auto detect module which find the CRIO and it's modules.
I set correctly the Ethernet port as "Ethercat" under max.
And finaly i tried to find the 9081 and 9144 under Labview and it did not show up (I select "Add target and Device" and then "discover existing target", there is "No items found").
Maybe a problem of configuration but i can not identified it...
07-26-2016 04:12 AM
The CRIO 9081 is finaly visible under Labview as you can see on the screenshot, but not the 9144.... I also set correctly the cable as Ethernet
07-26-2016 09:55 AM
Make sure to follow the steps in section 4 of this tutorial: http://www.ni.com/white-paper/10555/en/ for adding the EtherCAT slave chassis in LabVIEW.
07-27-2016 02:15 AM
