11-22-2011 08:27 AM
I updated NI-XNET on my system and the rt target and now i get this error:
Pible reason(s):
NI-XNET: (Hex 0xBFF6309A) The interface has already been opened with different cluster settings than the ones specified for this session. Solution: make sure that the cluster settings agree for the interface, or use a different interface.
11-22-2011 08:29 AM
I tried removing and re-adding my XNET databases as well as re-deploying with veristand.
11-22-2011 09:05 AM
MPCC,
Can you click on the CAN Port in the System Definition and make sure the Cluster settings were maintained? I've seen this option get reset before.
11-22-2011 09:41 AM
OK So I tried that. The X-NET Database section was empty. So I corrected it with the proper X-NET Database.
I verified that the CAN Cluster is accurate to the CAN Cluster in the databases. Then, I tried to redeploy with no luck. I am still getting the same error.
Now that I am heading down this path, I just updated to NI-XNET 1.4. Is it possible that a setting somewhere else got hosed when I updated?
11-22-2011 11:32 AM
It was a baud rate issue.
I had the wrong rate set up.It must have gotten reset with the other settings.
Thank you!
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
