05-13-2013 02:05 PM
Has anyone tried having several developers share an install of NI Veristand on a Windows Server machine? The developers would use Remote Desktop for initial development, and would all work together at the console for test/debug.
I believe the computer based license described here: http://www.ni.com/license/licensing_options.htm would allow this, but I am not sure if there is a problem with having multiple instances running at the same time.
Has anyone tried something like? How did it go?
Solved! Go to Solution.
05-14-2013 03:54 PM
Hi Clendon,
I think you could accomplish this with a few caveats.
You could have multiple real-time targets running unique system definitions created by the different developers. However, you would have to disconnect them from the development computer when accessing a different project. You would not be able to access multiple workspaces or multiple projects at once. As I see it, you could do something like this:
1) Open Project A and deploy to Real-Time target A
2) When you know it's working properly, disconnect target A from the project (by going to Operate>Disconnect)
3) Open Project B and deploy to RT target B
4) Disconnect project B
5) Reconnect to project A for debugging/testing
Is that what you're proposing?
05-15-2013 07:53 AM - edited 05-15-2013 08:07 AM
Posted by mistake and can't delete. Sorry.
05-15-2013 08:08 AM
Hi Alisha,
In my case, there is only one RT system. Also, we are colaborating on the same project. I was thinking that the developers could work "offline", not connected to the RT, on seperate sections. For instance Developer A would work on a device driver and Developer B would work on a model. The developers could use Model in the Loop or otherwise simulate inputs to test their sections.
When it comes time to deploy, then I was thinking the developers would have to work together at one console. Or some developers would have to work on something else while one used hardware.
I will back up a step. I am trying to figure out if it is reasonable for my company to order 1 copy of Veristand, and for the three developers on the project to share it. As I mentioned. all of us are working on the same project. The obvious, but also awkward way is simply to time share. We work in shifts until we are ready to integrate. I want to avoid this because that makes it harder to collaborate. (Also I like going home at 5.)
05-16-2013 03:03 PM
Hi Clendon,
The license agreement states that the software can only be used by a single person on multiple machines (with only on instance running) or by multiple users on a single machine (which would only allow one instance to be running). I believe what you are proposing (multiple people using it at the same time) would violate the license agreement: http://www.ni.com/legal/license/
If you have further questions about how many licenses you would need to buy I would recommend discussing it with a member of our sales team. They'll be able to speak to what you would need for your specific situation.
I would think you would at least be able to get away with using only 2 for three people as model development and driver development will not need constant access to VeriStand. You'll really only need it for testing.
05-16-2013 03:55 PM
Thanks Alisha,
This is the kind of info I was looking for.
