Hello everybody,
I'd like to create a model to run it in veristand from a VI but the problem is, that i can't find NI VeriStand on the tools, i'm working with Labview 2011 and NI VeriStand 2012, It's probably the problem with the compatibility. I have installed the NI Veristand 2012 already and i can work with it but directly from the VeriStand Icon, and from the VI it's not possible.
Could be that may be working with VeriStand 2011? or should i configure it.
I have today installed the Labview 2012 as Evaluation and i still unfortunately can't find the VeriStand on the tools
I hope i explain the problem good and you can understand the situation
Thanks for your help
Josef
